Old 08-19-2009, 02:33 PM
GWZ GWZ is offline
Default Purchasing an RV with ECI "group A" Cylinders?
I could use some advice. I'm considering purchasing an RV-6A with an O-320 that has low time (130hrs) ECI cylinders and pistons. I talked to someone at ECI and they said they aren't seeing any problems at all with the group A cylinders. Now that a year has passed have any of you had any problems or known of any "group A" cylinder failures?
Thanks, Gunther
Old 08-19-2009, 02:36 PM
Geico266's Avatar
Geico266 Geico266 is offline
Welcome to VAF
Someone smarter than me will be along shorty. I'm just the welcome wagon dude.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-19-2009, 03:54 PM
McFly's Avatar
McFly McFly is offline
FWIW I spoke with the ECI rep at Arlington last year. He said the problems with the ?B? group were caused by a new assembly technique and it was absolutely a valid AD/SB. He also said that ECI fought against the SB/AD for the ?A? group because statistically the failure rate was no greater that other cylinders out in the field (read their cylinders as well as their competitors). Good luck.
Hugh
Northern California
RV-7 Flying
Old 08-19-2009, 04:08 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Getting close to 1000 hours on my Group A's, and zero problems/leaks/issues....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-19-2009, 07:45 PM
frankh's Avatar
frankh frankh is offline
Default Issue free
On my groups A's after 400 hours
Frank
