Old 08-18-2009, 06:51 AM
Tbone's Avatar
Tbone Tbone is offline
Default Canopy drilling?
What procedures (that seem to work) on drilling the canopy holes for the #6 screws? I have read and seem to remember someone using a ceramic countersink and such. From start to finish what worked and drill bit sizes please?
___________
Terry
RV7
XP IO360
Old 08-18-2009, 08:17 AM
mikehoover's Avatar
mikehoover mikehoover is offline
I just completed this task for the windscreen/roll bar screws. I used a very dull #40 for the initial holes, countersunk with the microstop countersink, then enlarged to 5/32 with a unibit (long thin one) - 1/8" first, then 5/32". Drilled at low speeds and took my time. Worked really well in my 100 degree hangar. As for the sides of the canopy when installing the side skirts, the manual says to "pre-drill the canopy with a #30 drill through the canopy lower edges," then countersink and enlarge to 5/32". Why not the same #40 as the windscreen?
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 08-18-2009, 09:51 AM
Rupester Rupester is offline
Just drilled my canopy holes three weeks ago. Used a 1/8" Plexi bit, then a plain ol' #30 countersink, then enlarged with a 5/32 Plexi bit. No troubles at all. BTW, I tried the standard #30 countersink a lot on scrap pieces before I followed friends' advice to do so. They told me not to fret over the pricey ceramic/stone countersinks. At least 4 local builder/friends had used a standard #30 countersink with no trouble.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 09-19-2009, 02:17 PM
Tbone's Avatar
Is 5/32 large enough for final size? Will that be enough clearance for expansion?
___________
Terry
RV7
XP IO360
Old 09-19-2009, 03:00 PM
cyrilmclavin cyrilmclavin is offline
Default drilling canopy
Its not expansion that you have to worry about so much its the contraction of the plexi in the very cold winter temperatures especially in the skirt the plexi needs to be drilled oversized as the plexi shrinks more than the rivet through it,in the -30 to 40 that we get here in the northeast. Our canopy developed a crack from one of the skirt rivets but we were able to drill stop it.
cyril
Old 09-20-2009, 08:56 AM
Tbone's Avatar
My understanding (possibly wrong) is that the canopy, as a whole, expands and contracts. I don't think that the hole size does that? Is that what you are referring to? The reason I ask is that on my skirt I drilled to 3/16 and on the rollbar I used 5/32.
___________
Terry
RV7
XP IO360
Old 09-21-2009, 11:57 AM
mike newall's Avatar
mike newall mike newall is offline
Cool
Terry,
The simpler solution is don't drill !
Believe me, the Sikaflex method of gluing is very easy and gives a much better and less anxious result.
http://groups.yahoo.com/group/rvsqn/...unt=20&dir=asc
