Old 08-15-2009, 03:32 PM
noelf noelf is offline
Default ASI failure on "first flight"...
RV-6A (N6NF) had its maiden flight this past Thursday. A year ago or so, I had started thinking about whether I, or someone else, would be making the first flight.
I have not flown any in the last 12 years (13 years build time with 5,000 documented hours in the construction log book). I realized that if I wanted to do the first flight myself, I would need to get current as a pilot, then transition training in an RV. Even then, I questioned my readiness to cope with the unexpected on a (or my) newly airworthy aircraft.
Long story short, I consulted with a friend who has 1,000 plus hours in RV-4's, RV-6's, RV-7's, an additional 700 hours in an Extra, and about 10,000 hours total. He volunteered to perform the first flight.
The first flight went great. Everything functioned as expected...except that the air speed indicator "stuck" on 130 knots 3/4 of the way into the flight. The plane was slowed down, but he ASI still showed 130kts.
My plane has both traditional "steam gauges" and a Dynon 10A. The Dynon unit was turned off during the A/C start up as the pilot did not want to deal with the solid state gizmo. The pilot was instructed to turn the Dynon unit on and auto-magically, the Dynon unit provided the correct airspeed information.
The aircraft was slowed to slow flight parameters and a beautiful landing followed. The pilots post-flight brief showed no discrepancies (except for the steam gauge ASI), and a beautifully handling and flying aircraft. Now, he wants a Dynon unit for his RV-7.
I pulled the ASI from the aircraft (still showing 130 knots) and opened it up. The problem was the indicator pointer counter-weight was rubbing on the instrument dial face plate. A little reforming of the counter-weight was all the was needed to revert to a functioning ASI. I still need to hook it up to a manometer to verify the pressure vs indicated readings.
Sooooo, back to the original thoughts on the first flight. No, I was not disappointed that someone else performed the first flight in N6NF. I was elated that it flew, and it flew well. I was actually thankful that my friend had so much time in RV's, knew how they flew, knew how they "felt" and could deal with questionable ASI readings. For me, THAT is the reason that a qualified / experienced pilot be allowed to take that first flight.
Old 08-15-2009, 07:32 PM
terrykohler terrykohler is offline
Default IT'S MORE THAN THE FIRST FLIGHT
Keep in mind that it doesn't end with the first flight. The next 25-40 hours should be spent exploring the performance and handling envelope, and more importantly, documenting the results. If you have any feeling that you will be "learning to fly" during this time rather than looking at gages, running a stopwatch, recording data and fixing problems, you might want to consider someone else.
The idea is to have a solid POH after your test period. If you haven't completed all necessary testing during the time frame given by your DAR, please don't take your wife, kids, etc. for a ride. No sense in them becoming test pilots too.
Don't use someone else's numbers. These aircraft are still experimental, even thought many people are starting to think of them as "off the shelf production". Big mistake. Even bigger one if you're willing to risk the lives of family and friends without their knowing that the aircraft hasn't been fully and properly tested.
Terry, CFI
RV9A N323TP
Old 08-15-2009, 08:09 PM
Jamie's Avatar
Jamie Jamie is offline
Although Terry is spot on about the necessity for thoroughly testing these aircraft, I just wanted to clarify that there is absolutely no regulatory requirement for creating a POH for our aircraft. I'm sure Terry knows this but I wanted to point it out for new builders.
Old 08-15-2009, 08:16 PM
Mel's Avatar
Mel Mel is offline
Also remember that the test period (time frame) issued by your inspector is a MINIMUM time. You must complete you flight testing regardless of how much time it takes.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-15-2009, 09:27 PM
sandifer sandifer is offline
Default congrats
Noel, great to hear of the successful first flight! Must have been a blast watching it break ground for the first time. Enjoy.
Old 08-16-2009, 05:12 AM
Default POH
Jamie:
Correct. Operating Limitations are part of our airworthiness documentation which must be on board, as well as weight and balance data. Putting together a POH is a good way to ensure you've completed all necessary testing. Not absolutely required, but neither are starter motors or landing lights.
Terry
Old 08-16-2009, 05:29 AM
pierre smith's Avatar
Originally Posted by noelf View Post
.........RV-6A (N6NF) had its maiden flight this past Thursday. A year ago or so, I had started thinking about whether I, or someone else, would be making the first flight.
A very wise choice, Noel. Who'd have guessed an inop airspeed indicator on the first flight??? Ya never know.
Congratulations...take baby steps.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
