Old 08-14-2009, 10:56 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Lycoming Exhause Valve Guide SB
A friend of mine discovered some serious exhause valve damage to his O-360
and during the repair process he uncovered a Lycoming SB that addresses the issue of carbon buildup on exhause valve stems. I'm curious, how many have performed the inspection described by this SB? Also, what are the chances of having problems with carbon buildup when useing electronic ignition and running mogas? Comments welcome....
Here is the SB on the Lycoming valve guides: http://www.lycoming.com/support/publ...dfs/SB388C.pdf
And here is the Service Instruction # 1425 with reaming instructions: http://www.lycoming.com/support/publ...fs/SI1425a.pdf
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 08-14-2009, 11:22 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Cleaning Valve guides
I have done it on a small contenital engine. I dropped the exaust valve untied into the cylinder and cleaned the guide with emery cloth and a "Swizzle stick"(slotted bamboo or dowel). Fishing the valve back into the guide was done with two people using a magnet and two pair of forceps working through the spark plug holes.
The first one is a little scary, after one is done it's no big deal.
Andrew
Old 08-14-2009, 08:22 PM
az_gila's Avatar
az_gila az_gila is offline
Smile I did it on my Tiger...
...with a 600 hr Lyc. reman engine.
I failed two cylinders in the other direction - valves too loose - and did a top overhaul.
It is a worthwhile test since a loose valve can be just as bad as a tight one.
This is a picture of my Lycoming tool, but the SB gives dimensions for a DIY tool.
The above tool is usually modified to use a dial indicator to get direct readings. As shown above, the small screw on the right is adjusted to be close to the valve stem extension and a feeler gauge is used to get readings.
The tool depresses the valve a small amount as it is tightened down on the cylinder head - this lifts the valve off the seat without removing the valve springs. The version that Spruce sells does not do this.
Note that the SB also calls for cleaning the hydraulic lifters.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-14-2009, 08:42 PM
Ironflight's Avatar
VAF Moderator / Line Boy
As Gill well knows (as do many other Grumman refugees here in RV-land...), this SB was a constant source of discussion and frustration in the Grumman world for quite a few years. I left that world behind when I slid into my RV-8 for the first time, and have always been amazed that even with the same engines, no on in the Van's world ever mentions the thing - or valve failures for that matter.
I have never really figured out the difference - except that there seems to be fewer cooling problems in the RV's than in the Grummans as well....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-14-2009, 08:51 PM
az_gila's Avatar
Default And it's not even...
...consistent.
A local Tiger with an O-360 right at TBO borrowed my tool and his valves were all within tolerance....
My engine even has the hi-chrome "improved" valve guides, his did not...
We've measured a few RVs with O-360's and they have all been OK so far.
Paul
Gil Alexander
Old 08-14-2009, 08:55 PM
Radomir's Avatar
Radomir Radomir is offline
Maybe how you operate your engine has a lot to do with the end result? Just a thought...
Radomir
RV-7A sold
Old 08-14-2009, 08:58 PM
az_gila's Avatar
Exclamation Maybe...
...but the previous owner did 500 of those 600 hours - as well as the factory instrumentation that didn't even include a CHT guage...
I now have 4 cylinder EGT/CHT monitoring....
Gil Alexander
Old 08-14-2009, 09:01 PM
Paul
Could be SI1485A has something to do with fewer reports of valve problems. Lycoming switched to a better valve guide in 1996 and since March of 1998, all engines have been shipped with the improved guides. The inspection time was increased to 1000 hours, or half way to TBO, on engines with the new guides. That does not account for RV's flying with older engines, but many RV's do have later engines, much later than those on the Grummans. They've been around for a while.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
