Old 08-12-2009, 07:56 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Dynon users-P-lead resistor?
If you are one of the Dynon owners using a EMS or FlightDek180 and picking the tachometer input off the P-leads from the mag switch; did you have to vary the resistance from the recommended 30K ohm called out in the manual?
If so what resistor value worked for you?
Old 08-12-2009, 07:59 PM
flickroll's Avatar
flickroll flickroll is offline
The resistor supplied in the installation kit worked fine for an O-360-A1A
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 08-12-2009, 08:03 PM
Greg Arehart's Avatar
Ditto for my IO360. It certainly doesn't work well WITHOUT the resistor (you know how I know).
greg
Greg Arehart
N 7965A
Old 08-12-2009, 09:31 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
30K (actually 33K) was not enough for the RV-10's IO-540 and a D120 EMS. Added an additional 47K in series for a total of 80K ohms inline with each leg, still not enough... Still got erratic tach readings although it was better than with 33K. Ended up using 100K resistors in each leg, and bingo... perfect readings!
Neal Howard
Airplaneless once again...
