Old 08-12-2009, 11:37 AM
DBone DBone is offline
Default Pilot Side Stick Grip Buttons
Looking for ideas... I have a CS-8 grip from Tosten (http://www.tostenmanufacturing.com/c...aft-grip.html#). That gives me a hat switch for trim, a trigger button for PTT, then 3 more aux buttons. I'm thinking one will be AP cutoff, but I'm undecided on the other 2.
Regardless of avionics selection, I'd like to hear what others have put on the stick.
If you have specific suggestions for certain avionics, here's what my panel looks like:
EFIS: GRT HX
Autopilot: TruTrak VSGV
GPS/Nav/Com 1: Garmin 430
Nav/Com 2: Garmin SL-30
Audio Panel: PS Engineering PMA 8000
Xponder: Garmin 330
GPS 2: Garmin 696
Thanks!
Dave B
McKinney, TX (T31)
N517AD - RV-7A - Sold
N963TP - RV-7A - Partner
N10HW - RV-10 - Partner
Old 08-12-2009, 12:05 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Comm flip flop
My current plane has the Ray Allen grip with 4 buttons and PTT. I only have electric elevator trim, so I used the aileron trim buttons for AP disconnect and Comm 1 flip flop. Works great and easy to wire.
AP disconnect has proven very functional. I also like the flip flop.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-12-2009, 01:42 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Xpnder ident.
Radio freq flip flop.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-12-2009, 02:09 PM
sjjonesnz sjjonesnz is offline
I also have those stick grips and aside from having AF3500s my panel is similar, so...
Little button below trigger - (AF3500) audio alert mute
Trigger - PTT
Left button - (PMA8000B) COM1/COM2 flip flop
Right button - Autopilot (Dis)Engage
Hat switch (Forward/Back) - Elevator Trim
Hat switch (Left/Right) - Not used (or is that reserved for future use )
I thought about using a button for Tx Ident, but decided 'inadvertent application' might upset ATC a tad, also thought about using hat switch L/R for swapping screens on EFIS but thought that was a bit counter-intuitive.
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 08-12-2009, 02:12 PM
DGlaeser DGlaeser is offline
Default Mine are:
Trigger - PTT
Button under the trigger - A/P disconnect
Top left button - Comm 1 flip/flop
Tob right button - Com 2 flip/flop
Hat switch - elev/ail trim
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 08-12-2009, 03:51 PM
Jim Percy Jim Percy is offline
I have the same grip. I don't have aileron trim, so my setup is:
Hat:
fore/aft- elevator trim
side/side- nav/comm flip (comm to left (easier, more frequently used), nav to right)
right button- AP engage, disengage
left button- Alt hold engage, disengage
trigger- PTT
lower button- Xponder ident
Many who fly formation put the flap switch on the stick. I put my flap switch within thumbs reach of the throttle.
For ME, this has been the perfect setup and I wouldn't change anything.
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 08-12-2009, 04:35 PM
bcondrey bcondrey is offline
Aside from the obvious trim and PTT assignments, I've got the AP CWS/disconnect on the "index" button (below the trigger) with Comm#1 freq FF and GRT page flip on the top two.
Bob
RV-10 N442PM
Old 08-13-2009, 07:49 AM
Default thanks for the feedback... a few more questions
Thanks for all the feedback. Exactly what I was looking for! A few specific questions:
Bob - "GRT page flip"... do you use this a lot? I've never flown behind a GRT, so I'm not sure how useful it really is. Can you describe how you use it?
Jim - Which nav/com do you have that has remote switching for both? I don't think the 430 can be remotely controlled at all, and the SL-30 only flips the comm, or at least I thought. Which AP do you have that allows for alt hold off/on remotely? That's the way my old S-tec worked, but TruTrak told me I can't do it with theirs... Just total on/off.
Thanks guys!
Dave B
McKinney, TX (T31)
Old 08-13-2009, 08:59 AM
My Nav/Com is the CNX-80/GNS-480. I have a TruTrak autopilot- Digitrak with Altrak, though I have them wired together so the disengage button drops both. The Altrak must be engaged, and can be disengaged, independently (but wired this way it WON'T engage unless the Digitrak is already engaged).
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 08-13-2009, 09:17 AM
Frank Smidler Frank Smidler is offline
Default My stick grip buttons
PTT - obvious
Small button under PTT - Flip Flop (Icom 200A)
-be carefull not to push with full hand grip before first flight , normal
three finger flying at base does not cause a problem.
Left top - TXP Ident (I never use)
Right top - COM memory (works great with Icom)
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
