Old 08-11-2009, 10:23 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default F-6111 Rib Wrestling Match
I just finished fitting those darn F-6111 ribs for us slider dudes. I thought maybe someone out there in RV land might benefit from my adventures:
http://www.smittysrv.com/more_stuff.asp?ID=607
Smitty
Old 08-11-2009, 06:58 PM
llavalle's Avatar
llavalle llavalle is offline
Great. I can't thank you enough for you very detailed website.
Something I just don't feel like updating mine but knowing that it may help others pushes me!
I've got a question : where are you going to install the soundproofing material?
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 08-11-2009, 08:01 PM
SmittysRV's Avatar
Your welcome Philippe!
I went to an aircraft soundproofing workshop at OSH. The presenter was from PegasusAeroMarine.com. He had a lot of good tips about soundproofing your aircraft. They have many good articles on aircraft soundproofing on their website. After I went to the workshop, I toured the A-380 and saw some of the same stuff he talked about. I am going to get the vinyl nitrile sheets with self-adhesive back from Aircraft Spruce and cover every interior (sheet metal) surface inside the cockpit area. 1/4 inch in the baggage area and 1/2 inch in the forward area. Every since I lined the inside of my air compressor box with foam rubber, I've become a believer in it's noise reduction capability.
Have a goodun!
Smitty
