Actually this bolt should not be torqued too tightly. The reason for the slot is for the two brackets to pull apart and avoid ripping the end out of the fuel tank in case of an accident. The bolt is in "shear" only. I use a drilled bolt and castle nut with cotter pin.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
