Old 08-08-2009, 04:47 PM
msturgis's Avatar
msturgis msturgis is offline
Default Pneumatic Squeezer won't set -4 rivets
I have a pnematic squeezer from Isham's. It seems to have a hard time setting -4 rivets. i just set some 4-5 and it took a couple of pulls of the trigger to get the rivet to set. When I try and set a 4-6 it won't budge!
FYI I am running my compressor at 90-100psi.
Matt Sturgis
RV-8, Wings
N43MS Reserved.
Paid VAF 2012
www.mattsairplane.com
Old 08-08-2009, 04:49 PM
scard's Avatar
scard scard is offline
At the risk of stating the obvious. Make sure you're working at the end of the stroke. Sometimes, on a long rivet, you have to set it in two steps.
Scott Card
CMW E-Lift
Old 08-08-2009, 04:53 PM
mikegraycmg's Avatar
mikegraycmg mikegraycmg is offline
Default Set
Change your set so that the throw is either longer or shorter -- probably shorter will work. I had the same problem, and got this advice from Bob Avery. It seems that the device inside the squeezer that closes the jaws produces a different amount of torque at different points as it closes. Actually, I just reviewed Scard's post and I think he is probably closer to being right than I am.
Mike Gray, A&P IA, AET, KGPM, Grand Prairie, Texas
1956 Bonanza for sale.
Old 08-08-2009, 05:36 PM
airguy's Avatar
airguy airguy is offline
As mentioned above, the leverage of the squeezer is greatest at the end of it's travel. I run my squeezer at full compressor pressure, about 135, and have no trouble with any 4 rivets.
Old 08-08-2009, 05:44 PM
Mel's Avatar
Mel Mel is offline
80-90 psi should be plenty for any rivet squeezer for rivets up to and including 1/8" dia. If you need more than 90 psi, there's something wrong.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-08-2009, 07:41 PM
mcencula mcencula is offline
Default A word of caution
As others have noted, the squeezer will produce more squeeze the closer it gets to the end of stroke. One side effect this can have is if you are squeezing a long rivet and crank the pressure up, the squeezer may just barely be able to start the squeeze, but once it gets past the critical point, it has already built up full pressure in the pneumatic actuator and can snap closed really fast in an uncontrolled manner.
On long rivets I normally use my hand squeezer. It's quicker than adjusting the pneumatic squeezer to do it in two steps.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 08-08-2009, 08:00 PM
msturgis's Avatar
Thanks guys!
Shortening the throw did the trick.
Matt Sturgis
RV-8, Wings
N43MS Reserved.
Paid VAF 2012
