I have my infinity where....
you can power the fuel pump from the stick or the panel switch. The grip is wired (if you requested it that way) with heavy enough wire to run it without a relay. I just added a little red led of the panel mounted switch to indicate when the stick had power on. Seems to work fine.
Chuck Elsey
RV6 Start 7/06- Flying!
 N349CE
