Old 08-08-2009, 07:13 AM
ZU-RVZ ZU-RVZ is offline
Default Nosewheel Shimmy Video
Hi All,
A year or two ago there was a fascinating video taken of an 'A' model nosewheel shimmy.
I think it was discussed in this thread
http://www.vansairforce.com/communit...nosegear+video
I have found a few others but none as 'bad' as the one in the video.
The link in the discussion is now dead. Does anyone have a new link or a copy of the video for me?
Old 08-08-2009, 07:24 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I remember that video....
Just so you know, my 6A suffered that type of shimmy on it's very first landing (last Sept.). I let the nose down to quick, and the nose wheel nut needed to be torqued a bit more, as they loosen when new.
I'm now 91 hrs past that, and haven't had a landing shimmy since.
L.Adamson
Old 09-14-2009, 03:41 AM
Any more takers?
Old 09-14-2009, 04:52 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
I made a copy of one video from about this timeframe. I'm not sure if it is the one you mention as this one shows fore & aft oscillation of the nosegear spar and very little shimmy or left to right motion of the actual nosewheel.
If interested I'll put it up somewhere.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 09-14-2009, 08:22 AM
rvator51's Avatar
rvator51 rvator51 is offline
Here is one I posted back in 2006.
Nosegear shimmy
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 09-14-2009, 09:29 AM
DanH's Avatar
DanH DanH is offline
Clearly the fore and aft oscillation has nothing to do with fork nut preload.
I'm curious about a detail. Can someone post a few photos of a 7A engine mount and landing gear strut sans engine?
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-14-2009, 10:16 AM
GrayHawk's Avatar
Nosegear shimmy
That's the same one I have a copy of.
For the fore & aft oscillation shown, important info would be what type of nose wheel installed, whether there is a 'spacer' between the bearings on the axle bolt, torque on the axle bolt, rolling friction, etc.
GrayHawk
Old 09-14-2009, 11:26 AM
DanH's Avatar
None of those things matter if the wheel/tire assembly is truly round, and if the there is no variation is rolling resistance with each revolution.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-14-2009, 12:21 PM
Rick6a's Avatar
Rick6a Rick6a is offline
....I'm curious about a detail. Can someone post a few photos of a 7A engine mount and landing gear strut sans engine?
Dan,
I don't know if these photos of the engine mount fitted to my -6A can help satisfy your curiosity. I suspect this engine mount is very similar in design to the -7 series nevertheless, the shimmy condition has been known to occur in the -6 series too.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 09-14-2009, 02:53 PM
DanH's Avatar
Thanks Rick. I was thinking abut truss stiffness for the nose gear tube. Easy to make a structure strong enough, but sometimes difficult to make it stiff enough.
Dan Horton
RV-8 SS
Barrett IO-390
