Old 08-07-2009, 09:22 PM
flickroll's Avatar
flickroll flickroll is offline
Default Adding Air to Tires Inside Wheelpants
This is a problem on RV's! Back in my Christen Eagle days Christen used an inch and a half steel plate that covered a hole in the wheel pant that was used for adding air. An extension was connected to the tube valve and it was easy to add air...but I cannot find anyone who sells these covers. Anyone have a source? Right now it is a PITA adding air... Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 08-07-2009, 09:30 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I have a 1" hole than lines up with the stem. Then a 1" piece of PVC about 1/4" long is fiber-glassed to the inside of the pant. A 1" plastic plug from Lowes or Home Depot is painted the same color of the wheel pant. Looks great, and the plug stays, but is removable with just finger pressure.
I use one of those flexable air extentions, and a 10mm socket wrench to remove the multi sided valve cap.
L.Adamson --- RV6A (flying)
Old 08-07-2009, 09:34 PM
I have little 7/8" metal snap in plugs I got from the aviation section at Home Depot. They work just fine - they stay when they should and are easy to remove. Add a valve extension from NAPA, and the hardest part is lining up the valve with the hole...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-07-2009, 09:36 PM
Caveman's Avatar
Caveman Caveman is offline
Default One option
A lot of people use these. I bought them but have not installed 'em yet. Still trying to decide if I want to.
http://www.cleavelandtoolstore.com/p...sp?number=VSC2
http://www.cleavelandtoolstore.com/p...sp?number=VSE5
You can get similar covers at nearly any hardware store.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 08-07-2009, 10:27 PM
Finley Atherton Finley Atherton is offline
I painted a line on the tire with Liquid Paper correcting fluid that lines up with the split in the wheel fairing when the tire stem is adjacent to the hole. There may be something better than Liquid Paper although it seems to last well. I redo the line at each annual.
Fin
9A
Old 08-08-2009, 04:43 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Real Aircraft Hardware
When used on aircraft, I've always thought plug caps rendered a kinda "cheesy" look. As an electrician in a former life, I can't help but see them best used to plug open holes in electrical boxes. As an alternative to common hardware store parts, I use these tiny spring loaded devices. Held in place with two #30 rivets, they work quite well. Too bad AirVenture is over. Located at the FlyMart, B&B stocks them for $7.50 per. You can still give em a call anyway.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 08-08-2009, 06:28 AM
DarylT's Avatar
DarylT DarylT is offline
Default Valve Ext.
http://www.averytools.com/pc-1011-12...extension.aspx
Here is an extensition for going thru the hole in the wheelpants.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 08-08-2009, 06:45 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
I used the same sort as Rick. I bought mine from Spuce here:
http://www.aircraftspruce.com/catalo...ccessdoors.php
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 08-08-2009, 06:51 AM
L.Adamson's Avatar
That's why I use the plastic caps. They are light ( in case one drops from 10,000'), and have a smooth surface. Easier to install & remove, than the electrical caps too....
L.Adamson
Old 11-04-2009, 02:34 PM
N8RV's Avatar
N8RV N8RV is offline
Wow ... at $22.75 per, I'm liking the sounds of the plastic plugs a whole lot better!
I think I'll buy a few and paint them to match the wheel pants. If one magically disappears, I'll have spares.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
