Old 08-06-2009, 06:08 PM
flickroll's Avatar
flickroll flickroll is offline
Default RAMI AV-12L
Does anyone know if the RAMI AV-12L will pick up glideslope signals in addition to VOR/LOC? This is for an installation with an SL30 Nav/Com. The RAMI website does not mention GS for this antenna. Actually it does not mention LOC either but if it picks up VOR it has to pick up LOC. The specs for the Comant CI-157P specifically say it tunes GS, but it is about double the cost of the RAMI.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 08-06-2009, 07:29 PM
jetjok's Avatar
jetjok jetjok is offline
Default G/S Antenna
I am not familiar with this particular antenna, but usually the G/S antenna is a separate antenna. You are correct that the VOR/LOC antenna is one and the same.
On the spam cans that I used to work on, the G/S antenna was mounted on the windshield, and the VOR/LOC antenna was on the top of the cabin.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 08-06-2009, 08:14 PM
flickroll's Avatar
The RAMI and the Comant look the same. However only Comant says their antenna picks up GS.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 08-06-2009, 08:45 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Well, the SL30 only has one antenna input for NAV, so you HAVE to have an antenna that does VOR/LOC/GS. Louise's -6 has a cat-whisker antenna that performs just fine for all three functions, and the RAMI AV-12L looks to be a cat-whisker as well, so I'd be pretty confident that it would work. It doesn't take much to make a GS antenna - a stripped piece of Coax will do it - not very critical.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-07-2009, 05:43 PM
flickroll's Avatar
Called RAMI today and they said it picks up GS just fine. A splitter is required for radios with a separate GS input, for the SL30 just plug in the nav cable. Kinda what I thought, but good to check...
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
