Old 08-06-2009, 03:37 PM
Geico266's Avatar
Geico266 Geico266 is offline
Default Ray Allen Components
I have had several Ray Allen components fail in the last year and I was wondering what else is on the market for trim indicators, relays, servos?
I've gone though 2 REL-3 elevator trim indicators, 1 REL-1 trim relay, and the trim servo is sounding anemic.
Anyone else replacing Ray Allen components? Any replacement vendors out there?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-06-2009, 08:31 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I finally got rid of our last REL-1 relays in Mikey - those are the only components from Ray Allen I have had bad luck with (two sets in the Val, one set in Mikey). They will act all shocked that you've had a relay failure, when in fact, they replaced the REL-1's with REL-2's because there are LOTS of reported failures.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-06-2009, 08:54 PM
flickroll's Avatar
flickroll flickroll is offline
Look at www.tcwtech.com. Their Safety Trim works great, and if you use the airspeed switch, you can have two different trim speeds, a faster trim speed at lower airspeeds, and a slower trim speed at higher airspeeds. Works great.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
