Old 08-06-2009, 09:21 AM
wings05rv6a wings05rv6a is offline
Talking Pitot and static lines
I asked a friend of mine,( who helped me install my instrument pannel) what I should use to splice the petot and static lines. He advised me that the local hardware shop had barbed splicers commonly used for irrigation systems. So that is what I did.
But now I am second guessing myself. By inserting the bards into the 1/4 inch lines at those locations the inside diameter becomes smaller. Should I change this? And if I need to change it what should I use.
Bob
RV6A everything but the closing of the wings, getting close
Old 08-06-2009, 09:29 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Bob
Pitot, and static are both pressure measurements, not flow.
The system will do just fine as you have it, assuming no leaks.
Really small restrictions will slow the rate of change, but not the actual value of the measurements.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
