Old 08-04-2009, 05:53 PM
Redwagon Redwagon is offline
Default oil filter drip capture via "slime fighter"
I've seen some posts on using various scoops and troughs to capture or channel oil away when removing the horizontal oil filter on a lycoming, has anyone tried one of these? Sounds like it bolts directly to the engine somehow? Spruce and other sell the same thing.
Tim
http://www.vansaircraft.com/cgi-bin/...uct=drain-tool
Old 08-04-2009, 07:31 PM
rocketbob's Avatar
Just changed my oil last night, the 27th time on the RV to be exact. I have a tray that I stick in under the filter from the side, and all it is is a piece of 2024-T3 sheet 18" or so long by 2" wide, with a crease in the center. Other end drips over the bucket underneath. Crack the filter open and walk away for an hour. Total cost: $0.00, considering the piece was scrap. Not a drop anywhere.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-04-2009, 09:41 PM
Ted Farmin Ted Farmin is offline
Default Oil tray
I have a tray like Rocketbob's and I punch a hole in the top of the filter at
the rear area (side) then rotate filter one half turn and let drain while I drop the oil from the sump. A rag under the filter catches the few drops that are left when removing the filter.
RV-4 flying 2 yrs.
370 hours
Old 08-05-2009, 04:08 PM
s_tones s_tones is offline
Well, it's low tech but plastic food saver bags work very well.
