Old 08-04-2009, 09:49 AM
Lct727 Lct727 is offline
Default Building Time toward A&P License
I was wondering if anyone had knowledge on the required practical experience need to gain your A&P license and if so, would building an RV kit constitute toward the practical experience time needed. Thanks....
Old 08-04-2009, 11:52 AM
Mel's Avatar
Mel Mel is offline
Actually according to the regulations, all experience must be on certificated aircraft. The reasoning being that you are working to a "standard" (the type certificate).
Having said that, I know of several people who have obtained their A&P based on building amateur-built aircraft.
It depends on the FAA facility you are working with. It seems that the overall trend is to allow amateur-built experience to count.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-04-2009, 02:55 PM
mcjon77 mcjon77 is offline
There were actually two presentations at Oshkosh that covered this. Both presenters knew folks that did it that way. Both also said to find a FSDO that will work with you and keep VERY detailed notes on what you did during your build and maintenance.
Jon McDonald,
Was Building Sonex #1287
Probably starting an RV-14 project this summer.
Old 08-04-2009, 03:50 PM
loopfuzz's Avatar
loopfuzz loopfuzz is offline
Default FSDO
Like Jon said, it's up to the FSDO according to the examiner that I heard give the forum speech. He said there wasn't anything that said it must be work on a certificated aircraft. But that each FSDO may interpret it differently.
The examiner also mentioned that you don't have to have your work signed off by a A&P, but that keeping your own logs to show what you did is a very good idea. Which all of us builders are doing anyways!
Chris.
RV6
Maule M5
