Did you by any chance use a master solenoid for the starter???
Some solenoids require external power to the coil, and are internally grounded, while some have the coil hooked to power internally, and need ground supplied to the activation stud.
Good luck, also check the diode when you are done, they fry easily.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
