Old 08-03-2009, 04:46 PM
Noah's Avatar
Noah Noah is offline
Default RV-7 Oil Cooler Plumbing w/ IO-360
Anybody got any photos of the accessory case showing which ports are used for the oil cooler on an RV-7 IO-360? There are several alternative options and I am curious to see which ones are used. My engine, an A1B6, came off a Beech Sierra and used this port for the return line, but I think that the better port to use is in the middle of the case, as the other one is more prone to leakage with two seals to worry about. See photo:
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 08-03-2009, 05:01 PM
mahlon_r mahlon_r is offline
The two fittings depicted in your picture are from the engine to the cooler not return from the cooler. It doesn't matter which one of the two you use to go to the cooler, they are in the same port internally in the engine.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 08-03-2009, 05:07 PM
Noah's Avatar
Thanks Mahlon, understood. Just trying to figure out which one works best given the geometry of the RV-7 around the firewall in that area. In other words, does the center one interfere with anything? I think that one is preferred. Do people use a straight fitting? 45? 90?
Highest Regards,
Noah F, RV-7A
Old 08-04-2009, 04:54 AM
Noah,
Most everything I have seen (using the Lycoming style oil filter adapter) used the center port with a 45* fitting to go to the cooler.
Good Luck,
Mahlon
Old 08-04-2009, 10:25 AM
Noah's Avatar
OK, thanks Mahlon, Looks like I'll have to pop off the oil filter adapter to get the 45* on there, and remove the crankcase breather fitting to remove the other port body/fitting and put a plug in there.
Still looking for a picture though! What orientation is needed on that 45* fitting?
Highest Regards,
Noah F, RV-7A
