Old 07-30-2009, 06:19 PM
scsmith scsmith is offline
Default help with a few engine questions
OK, I'm doing the last few chores on my engine install and hookup.
A few questions on details that some of the experienced guys can help me with:
1) The little bayonet fittings that screw into the cylinder heads for the CHT probes appear to be NPT thread? Should I put some anti-sieze on the threads? It isn't sealing anything, so I see no need for actual pipe thread sealant, but anti-sieze might be a good idea?
2) The screw-on ignition harness fittings that screw onto the ends of the spark plugs - should I put anti-sieze on those?
3) Same for the automotive spark plug adapter inserts? Anything else special I should be careful about putting those in?
I have one mag and one light speed EI on an IO-360-A1A ( 200 hp)
Thanks!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 07-31-2009, 02:24 AM
gasman gasman is offline
1... YES
2... NO
3... YES
Old 07-31-2009, 12:09 PM
Default Thanks.
Thanks Gasman,
I did find in the Light Speed EI installation manual the details on the installation of the auto plug adapters. Confirmed that the get anti-sieze.
Thanks for the info, very helpful. Odd that in a full day, with 162 views,yours was the only response. I appreciate it.
Steve.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 07-31-2009, 12:44 PM
jetjok's Avatar
jetjok jetjok is offline
Default Anti-Seize Compounds
I use the Champion anti-seize for spark plugs and it would probably work for the applications you specify. However, for your intended use, i would get a tube of C-5 compound. we used to use it for hi temp applications on turbine engines and I have used it for years on all things EGT, exhaust, CHT, etc.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 07-31-2009, 02:55 PM
Robert M's Avatar
Robert M Robert M is offline
Originally Posted by scsmith View Post
Thanks Gasman,
Steve.
It doess seem odd except I think everyone is at Oskosh - everyone except for us REAL builders!!!
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 07-31-2009, 04:24 PM
Default thanks guys
Oshkosh? whats that? Oh yeah, maybe next year.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 07-31-2009, 04:35 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Gettin er done
I'll be done Thursday, I just don't know which one
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 07-31-2009, 07:58 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You'll enjoy it Steve - come out with the NASA gang next year - it's a lot of fun! Somehow I got parked literally next to the NASA building - I am wondering if Sprucemoose had something to do with that, or if I just got lucky....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-31-2009, 09:22 PM
scard's Avatar
scard scard is offline
Default No rock star treatment
Paul, you just got lucky. I inquired .
Scott Card
CMW E-Lift
Old 08-01-2009, 05:58 AM
Ironflight's Avatar
That was the only logical conclusion that I could come up with as well....too many airplanes! They were stuffing RV's in every empty spot they could find on Tuesday morning - and moving fences to do it when they needed to.
It's getting very sparse now....almost sad in fact.
Paul
Paul F. Dye
