Forget those plans. You do not need any jigs for the new -1 fuse. I have a work bench (3'x6' by 42"high). Once a few sub assemblies are built and the longerons are bent, you just need 3 sawhorses about 20" high and a 3'x4' piece of carpeted plywood (5/8") to assemble the bulk of the canoe. After the canoe is done, you need a rotisserie.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
