Noise balance
I have found a relatively equal amount of "noise" here on a couple of static port issues.
1) Use the rivet head (SD-42-BLSF stated earlier) to get proper static readings rather than using a flush port.
2) Find a more robust method to connect the tubing, even though many many say the Van's "cheesy" method is fine.
I prosealed and riveted a flanged fitting to the inside of the fuselage in order to have a 1/8" NPT fitting port for connecting the tubing. I will be using the SD rivet for the exterior port shape.
http://websites.expercraft.com/rzbil...y&log_id=39754
Bill Pendergrass
ME/AE '82
