Old 07-26-2009, 01:44 PM
whd721 whd721 is offline
Default Tip Up Construction Sequence
I am in the throes of canopy fitting & fitting & fitting... Several questions have come up I would like advice on.
1. Do you finish the Tip Up Canopy before finishing the fuselage/ panel/ firewall area?
2. Do you finish drill the canopy to the canopy frame before or after riveting all parts of the frame (to C-702 & WD-716)?
3. Do you bevel the inside of the canopy to fit C-702 tighter? Where does it show the inside of the canopy to C-702 intersection final finish?
I have tried the search function, but no joy. Are there specific key works for canopy fitting?
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, ?Simplicate and add Lightness?
Old 07-26-2009, 04:47 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default If it helps
Hi William,
Here's the sequence I used and things seemed to have worked out:
http://caura.dyndns.org/gallery/Canopy?page=5
The 7 and 9 are the same w/ respect to the fuselage and canopy.
Regards,
/\/elson
RV-7A Tip-Up
NW Austin, TX
