Old 07-25-2009, 08:14 AM
prkaye prkaye is offline
Default my metal oil door
Inspired by others on this forum, I decided to fabricate my own metal oil door. I used .064 aluminum, a hidden hinge, and a suprlus Hartwell latch I got from Spruce for $25. For somethign that is going to be operated thousands of times, I wanted somethign a little more ruged than Vans' fiberglass oil door and camlocks. I went through two fiberglass oil doors before I decided this. I had troubles getting the fiberglass door to really stay down flush, particularly at the corners. I also beefed up the lip under the door with extra layers of fiberglass, particularly where the latch grabs it. The metal door can be shaped perfectly. I also like how rugged it feels, particularly with the beefy Hartwell latch.
Photos below in case anyone wants to do something similar.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 07-25-2009, 09:34 AM
Lars Lars is offline
Very nice, thanks for posting the pics. Saved to my hard drive for reference when I get to that point.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 07-25-2009, 09:47 AM
DarylT's Avatar
DarylT DarylT is offline
Default Sweet
Very nice. Give ya $100 bucks for it right now!
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 07-25-2009, 10:00 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Nice job. Mine looks just like yours - a single Hartwell right in the middle. I used the f/g door however, and epoxied in some stiffeners on the underside. The whole setup has been solid for 378 hours now.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
