Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 07-23-2009, 10:07 PM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default New version of SPOT tracker announced.
I got this from a friend who works with some of the dev guys at SPOT.
"A new edition of the SPOT Satellite Messenger has been announced today, updating the successful first-generation device with many new features. The SPOT, an emergency communications device, has been credited with over 250 rescues to date.
This new version seems to have tackled nearly every weakness of the original. Key improvements are:
? An improved chipset and antenna for better reception under canopy
? A GPS acquisition light
? A ?message sending? indicator light
? Illuminated buttons
? Protective covers over SOS and Help buttons to prevent accidental transmission
The new edition is also 30% smaller and lighter, weighing in at 5.2 ounces. A new custom message button lets you send out a pre-programmed message (this is in addition to the ?OK? button found on current models).
No word on price yet, but the new model is expected to be available later this fall."
Bruce
Richmond, VA (KFCI)
RV-10 (520+ hours since first flight in Nov 07)
RV-8 (500 hours, sold Sept 07)
Old 07-24-2009, 03:06 PM
RBD's Avatar
RBD RBD is offline
And here's a picture:
I'm hoping one of you Osh attendees can get more details (i.e. pricing.)
Ryan
Tampa, FL
RV-4 (sold)
RV-8 (sold)
Xtreme Decathlon (borrowing)
Old 07-27-2009, 09:59 AM
bkilby's Avatar
bkilby bkilby is offline
These are already posted on aircraft spruce stating they are available in Sept 2009. They are listed for the same price as before - $149.95
http://www.aircraftspruce.com/catalog/pspages/spot2.php
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 07-27-2009, 09:09 PM
BillSchlatterer BillSchlatterer is offline
Default Signal Frequency
I understood that the Spot signal was too infrequent to use for good continous tracking on the web. Something like every 2-5 minutes which is a long time at 170 knots. The home built units apparently can be set to update every 10 seconds or so.
Anybody have any details on the Spot? Is the update time OK or adjustable?
Bill S
7a
Old 07-27-2009, 09:21 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Spot is every ten minutes, but has a 911 button for a near instantaneous GPS position report if really needed. This is e-mailed, as well as cell phone calls to people on your list. The 911 button would need to be pushed though. It also has the I'm Ok button to let people know.
I like SPOT because I don't do anything but push the buttons. It's portable & doesn't have to be wired to anything. The ten minute intervals still provide a good track for cross country flights, although it could increase the distance between points to 30 miles or so. It also uses GPS and satellites which have been very dependable for almost the year that I've owned one.
L.Adamson
