Anthony,
That picture on Vince's website showing the Rocket Steering Link on the red TW is actually my tailwheel, after I replaced my original Van's TW with the SEGA TW that Vince sells.
I have not noted any shimmy at all, and I land on concrete/hard surfaced runways most of the time. However, your post did get my attention, so I looked at the links you provided, and then looked at the pics of my TW on Vince's Flyboy Accessories website, and those of Wayne Hadath's TW (who makes the Rocket Steering Link...see it here:
http://www.decisionlabs.com/QuickPla.../?OpenDocument)
I wanted to look at both to see if the conversion from the Van's TW to the SEGA TW increased or exacerbated the negative camber. I'm away from home and can't compare the two TWs in person, but in both pics, the negative camber is evident, and I don't think the SEGA TW increases it. It appears to me this is the result of the angle formed by the TW pivot and it's attachment to the spring (the pivot is angled forward at the top). I do not know for sure, but I think that is a fixed (welded) angle (and if that is an incorrect statement, I do hope it gets corrected or modified by a follow-on poster).
All that being said, my TW has been very solid, both with the Van's TW and the SEGA TW. The SEGA TW does seem to steer a bit more easily, and changing to it did lift the tail very slighty, so vis over the nose is very slightly increased. With the Rocket Steering Link, the control arm is notched and a pin protrudes into the notch when the tailwheel is aligned in trail, providing a steerable tailwheel, and good control. Perhaps that also mitigates any shimmy tendency as well.
I hope I read/understood your post and links correctly, and my description above jives with what you are looking at. But bottom line is that so far, FWIW, I've had no shimmying with either the Van's or SEGA TW.
Perhaps Vince or Wayne will see this and chime in with their thoughts, and it'd be interesting to see if those with springs (versus a RS Link), have different experiences.
Bob
