Yep, you cut a hole in the subpanel.
You attach the radio from the sides using angle brackets that you make from aluminum angle.
I can't remember the hole size but I cut small and filed to fit.
Look close at the SL40/327 cutout. You can see the simple brackets you make.
Here you go:
Before I put on the last skin I think I'll reinforce the cutout I made to the subpanel using angles.
