Old 07-21-2009, 06:01 PM
fstringham7a fstringham7a is offline
Default RE:#1 egt high????
Today was hanger time while my broken starter finds it's way to Sky Tec.
I decided to check Dynon D120 EMS numbers while the plane is static in the hanger. The #1 EGT climbed to 1900 degrees F while #2,3,4 were all ambient temp....Interesting anomoly.....Dynon support suggest a check of the dsub #27 pin for wiring integrety and 4 ohm status....which I will do at my next visit to the airport.
Anyother ideas out there in Dynonland
Frank @ 1L8 ...RV7A... Phase 1 kinda
Old 07-21-2009, 06:39 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Default egt
I had a similar condition. What it turned out to be was the probe connection was grounding out to the intake pipe of which I had it secured to. Once that was rectified, all was good.
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
Old 07-21-2009, 06:58 PM
Hi Gary
Thanks for the heads up on this issue. Two questions. 1. How was it grounding out? 2. What was your fix?
Old 07-21-2009, 07:45 PM
C-FAH Q's Avatar
the wire connector had a small edge of metal that was had worn through the heat shrink I had placed around the connection and was grounding out by hitting the intake pipe going from the sump to the cylinder. I filed off the sharp edge off the connector and put a thicker piece of heat shirnk on it.
Gary Wilcox
RV7 Sold
C-FAH Q now N281CT
Old 07-21-2009, 08:15 PM
Default RE:Thanks....Eye Exam
Gary
Thanks for the reply and do I need an eye exam or what INTAKE TUBES not Exhaust...........
Makes sense on the ground problem. This has been hit my way by you, Mike at Dynon and Jim a EE hanger buddy. I will begin the trace tomorrow to see where the problem is at.
Old 07-21-2009, 09:15 PM
mark kenworthy mark kenworthy is offline
Hello Frank
My problem was my probe wire at the connection it was grounded to a sheilded spark plug wire. Was hard to find.
Hope all goes well
mark
Old 07-21-2009, 09:26 PM
n505at n505at is offline
Default Sensor Wire problem
I think I had a CHT sensor wire contacting a plug wire. Grounded the plug and caused way high CHT temps. I separated the wires and all seems OK. Thread posted on the Maintenance Forum
Roy Samuelson
RV7A
