Old 07-20-2009, 10:44 AM
niblettda niblettda is offline
Default SafeAir1 Pitot and AOA Install
Sorry to cross-post, I screwed up and put this in the model specific forum and don't know how I could move it.
I'm currently at the stage that I would like to run my pitot and AOA tubing from SafeAir1. I already went through the "fun" of installing conduit into the wing ribs on the QB wings and the thought of having to try and drill more holes in the wing walk doubler ribs isn't appealing.
So my question is the snap bushings provided by Van's look like they are 5/16 ID and 7/16 ID. I assume one is for the Van's pitot kit and the other was intended for running wires through. The SA1 kit uses 1/4 OD tubing.
My thoughts are that I could get rubber grommits that might be 1/4" ID and the right size for the existing hole. Also I suppose I could do something to "build up" the area where the tube goes through the existing snap-bushings.
I'm wondering what others did in this situation. The obvious possible vibration concerns me, but maybe I shouldn't be so concerned since the tube will be rubbing on the snap-bushing.
As a side note, I love searching for something (like this) and coming away without the answer, but answers to other things I didn't even know I had questions about. I'm going for the move the pitot tube in a couple of ribs and making a doubler plate suggestion that I found on other installs of the SA1 kits.
David Niblett
RV-9A QB
http://www.n396dk.org
Old 07-20-2009, 06:58 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
What size hole are you trying to "build up" for the tubing?
FYI... ACS sells three different OD sized snap bushings with a 1/4" ID.
http://www.aircraftspruce.com/catalo...napbushing.php
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 07-21-2009, 07:49 AM
See now, I never even thought to look for a different sized OD snap bushing. Now that you say that it seems so obvious. I just thought all snap bushings were a fixed thickness and you drill the hole based on the ID size + thickness.
Thanks Brad
David Niblett
RV-9A QB
Old 07-21-2009, 11:17 AM
paul330 paul330 is offline
The standard VANS aluminium tube is 1/4 od - the same as the plastic tubing from SafeAir. The bushings provided by SafeAir have a smaller od than the VANS units. If the quickbuild already has the tooling holes enlarged to fit then you can use these with the supplied VANS bushings. If you are fitting AoA then you will, of course, need to drill for a second run.
Disclaimer - I m working on a -10 but I think the wing arrangement will be the same.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
