Old 07-19-2009, 05:17 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Thread for stitching baffle fabric?
Is there a special thread used to stitch baffle fabric FWF or does one just use normal heavy-duty sewing thread?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-19-2009, 05:21 PM
There is no real reason to stitch it if you cut, form, and attach it properly.
That said, if you're gonna stitch it anyway, I'd suggest dental floss.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-19-2009, 05:46 PM
Mel's Avatar
Mel Mel is offline
Personally, I prefer "peppermint" flavored.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-19-2009, 05:52 PM
Ted RV8 Ted RV8 is offline
Default Lacing Tape
I used lacing tape like this:
http://www.aircraftspruce.com/catalo...acingTapes.php
It is holding up well. I only used it to tie the baffling fabric in place to hold it when first putting it on. Once the baffle material gets hot and runs a few times it will take a set and hold in place well. I still have the lacing holding it though. I used it in the corners and were the material laps itself.
Ted
Old 07-19-2009, 06:31 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Ditto!
Ted
I did the same.
Jim Sharkey
Old 07-19-2009, 08:08 PM
Thanks for the ideas.
The reason I ask is that I chose to use two pieces of fabric on each of the baffle sides rather than the 4-6 pieces Van's plans call out. I figured I'd get a better seal that way. For the most part I have, and on my very first try. However, right where the side baffles bend inward toward the front, I ended up with the logical bulge when I put the cowl on. I found that simply slitting the fabric at the bulge allowed the fabric to overlap very slightly and now I have a perfectly sealing baffle over the inlet ramps and all the way aft. I'd just like to stitch up that overlap a little to keep the forward fabric overlaying the aft fabric and not vis-versa. I may even butt joint them and lace them together if I want a smoother joint.
The ACS lacing noted above sounds ideal, but I don't need a whole roll at $18-22 a pop, so I'll try to find someone to borrow a few inches from someone or use some dental floss I guess.
Thanks again.
Steve M.
Ellensburg WA
Old 07-19-2009, 11:48 PM
flyinmonque flyinmonque is offline
Default Red RTV......
Steve,
Try a little of this. Will almost work like a glue. Should take care of your problem. Wanted to call you and see how it's going but I misplaced your number. Coming up that way soon. PM me your number if you will. Will try and stop by again.
Dave
Old 07-20-2009, 04:02 AM
tinman tinman is offline
Pliobond glue also works well. It smells pretty bad, though. (I find that the taste is better than Pro Seal...a bit more earthy with subtle hints of ear wax if served at room temperature.)
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 07-20-2009, 05:16 AM
terrykohler terrykohler is offline
Punch a small hole thru both pieces where you want them to overlap. Fasten with a zip tie. Remove (or not) tie after 10-15 hours of flight time.
Terry, CFI
RV-9A N323TP
Old 07-20-2009, 06:19 AM
USCANAM USCANAM is offline
Default Lace it
Steve
I used the lacing I had left over from the fabric on my One Design.
I still have about a mile left over. E-mail me your address and I'll send you enough to do the job.
I drilled 3/32 holes in the fabric, laced it, then when all was finished, used black touchup paint on the lacing.
The areas not laced is where the baffles separate,
Jack
rosenracing@comcast.net
