Old 07-18-2009, 05:02 PM
fstringham7a fstringham7a is offline
Default RE: Skytec Starter ????UPDATE 07/20/2009..update 07/28/2009
Prepared for flight #4.....Having Fun.....Big Grins......Clear Prop......
The sound many of us know if a starter not engaging!!!!!!
Check this out????
I have read the threads on this but do have a question which in the end may be one of those....."I told Ya so".
How many of you folks have the brace between the starter and the alternator or not.
BUZZ has been starting real smooth until the start up this AM.
I will be calling SkyTec Monday. and maybe B & C for some more wallet lightening...............$$$$$$$$$$$$$$$
Frank @ 1L8 ...RV7A... Phase 1
Old 07-18-2009, 05:26 PM
John Clark's Avatar
John Clark John Clark is offline
Default Just a thought...
In the bottom photo the forward part of the mounting surface on the starter doesn't show contact like the back and sides. I would question if the forward dowel pin was free to seat all the way into the case. If not, torquing the nuts would certainly stress the mount and could cause it to fail as it did.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 07-18-2009, 05:41 PM
Mel's Avatar
Mel Mel is offline
My Sky-Tech Hi-Torque starter was installed February, 1995.
Not a problem since!
BTW, I've never used the alternator brace.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-18-2009, 05:42 PM
AX-O's Avatar
AX-O AX-O is offline
WOW !! That is the first time I have ever seen that failure. How are the teeth on the starter and flywheel? Does it look like the teeth did not line up and that caused the failure?
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 07-18-2009, 06:04 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've never seen a break like that one either! Give SkyTec a call - They've always been super to work with.
Oh, I have always thought the the brace was there for the alternator mount's benefit, not the starter. I might be wrong...but I doubt that was your problem.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-18-2009, 06:58 PM
yakdriver yakdriver is offline
I agree with John. It looks like the front dowel might have been bottomed out before the flange seated. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 07-18-2009, 07:13 PM
RVadmirer RVadmirer is offline
Saw the same general failure on a Cozy at Arlington last weekend. Broke on both sides like that. Maybe a bad bunch of castings.....?
Good reason for at least one mag - he could have proped it and flown home but it just wasn't that simple.
PS: REALLY beautiful engine, by the way!
Old 07-18-2009, 08:43 PM
rvbuilder2002's Avatar
Paul
I think Paul is right. The brace is for the alternator bracket.
This may very well have been caused by a problem with the starter, but if you are using a key style ignition switch, their is another thing you should also investigate. Check whether the grounding bar is installed on the key switch for grounding the right (non impulse magneto) during start. If you are not using a key switch, verify that you are only activating the impulse mag. during start. If you have electronic ign. in place of the right mag., ignore the above info.
Scott McDaniels
Hubbard, Oregon
Old 07-19-2009, 05:42 AM
turbo's Avatar
turbo turbo is offline
Default amazing!!!!!!!!!!
nice to know you can hand prop these 0-360's. the fly wheel looks a bit banged up. looks like it was bolted up flush, was the forward pin the right size? very interesting.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 07-19-2009, 06:40 AM
dan's Avatar
dan dan is offline
Did you get a kick-back? Got a funny feeling that if you have an EI, Sky-Tec is gonna assume that you did...
Dan Checkoway RV-7
