Old 07-15-2009, 08:29 AM
Jim Lewellyn's Avatar
Jim Lewellyn Jim Lewellyn is offline
Question Good Source for Aluminum Sheet??
I am in the procees of a panel upgrade and need to purchase some aluminum sheet. I need a 2' x 4' sheet of 2024T3 - .19 thickness. Any suggestions on a good place to purchase?
Jim Lewellyn
N6312V
RV6 - O-320 FP
GRT Sport & GRT AP
Old 07-15-2009, 08:54 AM
647jc's Avatar
647jc 647jc is offline
ACS can ship 2 by 4 feet pieces of aluminum at a fairly reasonable rate. Larger pieces shipping costs can get pretty expensive.
03-28850 2024T3 ALUM SHEET .190 X 2X4 $231.95
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 07-15-2009, 10:19 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Does it HAVE to be 2024? For panel inserts you could use 6061-T6, which might be easier to find locally. Either way, check your local metal supply house (or local stamping/fabricating/etc. shop). They will usually whack you off a chunk or two (spare).
For my panel re-do, I used the old panel to make the subframe and used 6061 inserts.
Mike W
Venice, FL
N164WM
Old 07-15-2009, 10:27 AM
airguy's Avatar
airguy airguy is offline
Wow! I didn't realize sheet was that high...
About a year ago I bought a 4'x12' roll of .040 2024T3 Alclad from another builder in Dallas for $300. I knew I got a decent price on it at the time, just didn't realize HOW decent...
Old 07-15-2009, 10:47 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Unless the OP had a typo, this is thick stuff he wants, .19" is pretty much equivalent to 3/16th.
That is a bunch of beer cans.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-15-2009, 11:03 AM
647jc's Avatar
Actually if you consider the amount (weight) of aluminum purchased, the $231.95 price for a .19 thick 2 by 4 sheet is about the same (within 4%) as $300.00 for a .04 thick 4 by 12 sheet.
Joe Condon
Ankeny, Iowa
Old 07-15-2009, 12:48 PM
Default Al. Sheet
Thanks Mike and others......... My plan is to use the existing panel and make inserts that will replace the exisiting inserts that presently house the 6-pack and engine instruments. Thanks for the suggestion regarding 6061-T6. I will take a look around locally and see what I can find.
Jim Lewellyn
N6312V
RV6 - O-320 FP
GRT Sport & GRT AP
Old 07-15-2009, 01:05 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Default Try Metal Supermarkets
These guys are a national chain, and there may be one in your town. I use them quite a bit for the one-off oddball purchase I need right away.
Check out their website:
http://www.metalsupermarkets.com/MSC-home.aspx
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 07-15-2009, 01:11 PM
n8zg's Avatar
n8zg n8zg is offline
Default Yard Aircraft Tools
You won't find it detailed in the catalog or online, but The Yard has a large selection of metals, all sold by the pound. www.yardstore.com
Neal George
Navarre, FL
CherokeeJet N9586J
RV-7 N8ZG (all the loose ends)
Continental Aerospace Technologies, Product Support
Old 07-15-2009, 03:23 PM
rbibb's Avatar
rbibb rbibb is offline
Check your local precision sheet metal fabrication shop (especially one listed as doing defense or aerospace work). They may have a "drop" piece left over from some job they will sell you at a reasonable cost.
I usually buy the stuff in 4x12 sheets when I have a job for a customer but rarely is all the stuff used. I'll see if we have any but I'm pretty sure we don't. A more local company would avoid shipping charges.
6061T6 is about 2/3 the price per pound of 2024T3.
5052H32 is even less per pound and would be OK for a panel blank.
Any sheet metal shop doing aluminum will have some 5052....
