Old 07-15-2009, 04:32 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Default Master Solenoid sticking
I need some help!
I have a master solenoid, Cole Hersee 24143 which is 200A continuous rated which supplies the main connection of power from the battery to the rest of the plane.
the solenoid will switch on and off all day, however after flying (and an engine start) when the master is turned off the solenoid stays closed for anything up to a minute or so.
Am I likely to have contacts that are welding closed? Is there a residual magnetic force keeping it closed?
Have I done something wrong here?
Cheers
DB
Old 07-15-2009, 04:55 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default solenoid
Check to see if your clamping diode is shorted. do you have the diode installed correctly? Temporarily disconnect it and see if your issue is resolved. These things will leak to ground when hot. Just found almost the same issue on a friends Grumman. It was a leaking diode killing the battery on the starter solenoid.
Hope this helps,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 07-15-2009, 05:19 AM
RV10inOz's Avatar
No Diode problems. And yes its installed the right way around, otherwise they vapourise!
I also have a diode on the starter solenoid, however this is the master we are having issues with.
Its the solenoid STICKING on that is the problem. I am wondering if the starter motor could be drawing well in excess of the cont. rating long enough to weld the contacts a bit.
Cheers
DB
Old 07-15-2009, 06:18 AM
Sid Lambert Sid Lambert is offline
You may be on to something there. You can over current the master during starting and cause it to stick. I installed a better battery (PC680) and the problem went away. Maybe your timing is too high and causing kickback? Anything that can cause an extra load during starting will cause it to stick.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 07-15-2009, 06:29 AM
Originally Posted by RV10inOz View Post
I need some help!
Cheers
DB
Get a new one and change it out. It will not fix itself.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 07-15-2009, 07:21 AM
Rick S. Rick S. is offline
I had the same issue, change it out. They are not the most precise piece of equipment. It's real hard to hook one of them up wrong so go easy on yourself
Rick Sked
Old 07-15-2009, 03:02 PM
RV10inOz's Avatar
Ahhhh you guys crack me up
This is the second one........ it is a much bigger battery, the 680 is my avionics back up and the main is a 925.
oooohhhh and yes I have hooked them up right!
I might just phone the folk at cole hersee now and ask for tech help.....as they are at work at the same time as I am off to work!
Any more suggestions are welcome. Coz it just Don't make sense!!!! (as Foxworthy would say)
Cheers
Old 07-15-2009, 03:21 PM
MJarreau MJarreau is offline
The contacts we use in the industrial world don't weld very quickly. Is there another energy source that could be tied to the solenoid? Solenoids don't take much to "hold" after they have been fired - that is, if they are like those we use.
I look forward to learning your resolution.
Cheers!
Michael
DUES REMINDER: JAN 2021
Old 07-16-2009, 03:12 AM
RV10inOz's Avatar
And so am I.....
I have installed a really serious solenoid now 225A continuous rated with 600A inrush capacity from Cole Hersee........what more can I do? I am sure the coil is collapsing.....well I think I am, if I cycle the switch I can hear the springs and the slug banging in and out.....but the contact stays made things are still alive .
What kind of solenoids has everyone else been using?
DB
Old 07-16-2009, 10:20 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
DB
This sure does sound like the contacts are welding shut-----at least partially so.
I would look for something that is causing a low voltage problem in the start circuit-----engine ground maybe------often times low voltage causes the amps to skyrocket as the load tries to pull the same wattage, which is the real measure of work done.
W=AxV
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
