Old 07-13-2009, 06:08 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default RV-8A Flexible Brake Lines
Has anyone here installed flexible brake lines on an RV8 or 8A?
If so, how have they performed for you?
Where did you have them made?
Any and all comments and suggestions are most welcome.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 07-13-2009, 06:48 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Bonaco
You might talk to this guy , he has pre made setups for most models of RVs.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-14-2009, 09:08 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by jeffmoreau View Post
Has anyone here installed flexible brake lines on an RV8 ........Any and all comments and suggestions are most welcome.Thanks
I made up my own flexible brake lines using Aeroquip 303-4 hose and Aeroquip 491-4 hose fittings. It is not a difficult assembly for the homebuilder to fabricate. While not flight tested on my RV-8 fitted with Grove gear, ground operations have proved normal and I anticipate troublefree performance on these hose assemblies just as the nearly identical hoses I assembled and fitted to my old Cessna 150 and used for many troublefee years.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
Old 07-14-2009, 10:02 AM
Beancounter Beancounter is offline
Default Flex brake lines
Another option is to use the flexible ends meant for a grease gun. Readily available, inexpensive, and meant for high pressure. However the ends are NPT.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 07-14-2009, 11:01 AM
Ramendala's Avatar
Ramendala Ramendala is offline
You can also try:
http://www.holley.com/division/Earls.asp
Or even Spruce
http://www.aircraftspruce.com/catalog/appages/aq666.php
Ryan
Ryan Amendala
Hillsboro, OR
Old 07-14-2009, 02:09 PM
scsmith scsmith is offline
Default I got mine from Bonaco
I made an aluminum angle bracket that attaches to the wheel fairing plate, and holds a bulkhead elbow fitting, this makes the transition from the aluminum brake line tubing to the flex line. 13" flex line forms a 180degree loop inside the wheel fairing.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 07-15-2009, 05:25 PM
Bushcaddy Bushcaddy is offline
Default Try Earl's
Earl's has off the shelf, stainless steel wrapped teflon brake lines in just about any length needed: www.anplumbing.com
Don...
Plymouth, MA
Varga 2180; N2C
http://www.n2charlie.com
2013 Donation Made
Old 07-15-2009, 06:15 PM
Mike S's Avatar
Senior Curmudgeon
Exclamation Check the flair
Please be careful when ordering "Off The Shelf" stuff from automotive houses----be SURE they are furnishing the correct flair angle.
Lots of automotive supplys are now carrying AN fittings, be sure to check.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 08-03-2011, 04:13 PM
John Ciolino John Ciolino is offline
Default RV-8 flexible brake lines
I installed a braided brake line just the way Rick Galati did in his pic. But at this annual I had to change my brake pads and the straight fitting kept me from removing the caliper; it would not clear the arm that supports the wheel pants. I had to open the line by removing the straight fitting to get the caliper off. So, I now have to add fluid and bleed the brakes again (which is a messy job and one which I don't like.) It looks like I have to use a 90 degree elbow on the caliper and a longer brake line to avoid this problem in the future. Have anyone else run into this? Do you just live with opening the brake lines or has someone come up an ingenious solutions?
John Ciolino
RV-8
N894Y
