Old 07-13-2009, 05:41 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Question Actual current for Airflow Performance pump?
Half electrical / half fuel injection question. Searched, but cannot find solid answer.
Does anyone know the ACTUAL current draw of the Vans/Airflow Performance fuel pump? I already have one, but don't want to run it while dry. Trying to plan the elctrical system layout. Thanks.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 07-14-2009, 12:10 AM
vlittle's Avatar
vlittle vlittle is offline
3.77 amps, 10A circuit breaker, 14awg wiring. Courtesy Vertical Power.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 07-14-2009, 07:07 AM
The "actual current" is 5.9 amps according to my Electronics International volt/amp meter. I checked it just for you.
I believe the pump we use is an Airtex model E8228 with appropriate attach fittings, is rollervane, selfpriming, 100-125 psi and will move 38 gph.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 07-14-2009, 10:02 AM
Jeff A's Avatar
Thanks guys. I appreciate the special effort David.
Jeff Atkinson
