Mel is THE DAR Extraordinaire...
Mel, Just want to say THANK YOU for setting me (and by proxy, my local FAA FSDO Airworthiness Inspector) straight on what Phase 1 and Phase 2 documentation was needed to be carried in my recently inspected RV-6A.
For those builders that have yet to submit the paperwork for an Airworthiness Inspection and the subsequent Operating Limitations, you should review FAA order 8130.2F, CHG 1 (or the latest revision). This document (Airworthiness Certification of Aircraft and Related Products) can be downloaded from the FAA website. It is a 350+ page document, but the section you want to focus on is Section #153.
This section contains all of the paragraphs (and numbers) that will be used to create your specific Operating Limitations for the Phase 1 and Phase 2 documents. It appears that they get copied (as appropriate) and pasted to create the final document. You should be able to review paragraphs 1 through 28 and compare them to your specific OpLmts.
Section 147, paragraph d.) states that the FAA must prescribe all operating limitations for phase 1 and 2 as appropriate.
It is the "as appropriate" that had my FSDO folks interpreting...well, differently. They thought that it meant that the phase 2 OpLmts document was optional. In fact, they needed to create a whole "new" document and pull in the appropriate paragraph numbers (select from numbers 1-28) to create the Phase 2 Operating Limitations. They had checked with Oklahoma City, got the "word" and I now have all the OpLimts for phase 1 and phase 2. I don't know how many experimental a/c have been given only the phase 1 documents from this office. Hopefully, they will review their records and contact the appropriate a/c owner/builders.
So Mel, thanks for setting me straight on what was really needed.
