07-12-2009, 07:31 PM
Can I secure the primer lines this way?
I've been thinking of different ways to secure my primer lines, and I came up with this idea...
Is this an acceptable method to do this? It's just a standard non-mil spec zip tie, and clear vinyl tubing. It works great to keep the line from moving, but I wonder about the proximity to the exhaust.
Yay? Nay?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
07-12-2009, 08:07 PM
Sweet
But I would use automotive fuel hose instead of the vynil tubing..Its nylon reinforced and won't melt.
Frank
07-13-2009, 09:35 AM
I'd also be concerned about the zip-tie chaffing the copper tubing. Easy to fix. Take a 2" section of the tubing (I usually use the harder Poly tubing), slit it and place it around the copper tubing. Zip-tie this to the copper tubing and use it to prevent chaffing from your zip-tie to the manifold you have shown.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build  )
N621TR In unrestricted operation
07-13-2009, 10:08 AM
I would avoid the zip tie in that location. I have my primer lines in that area secured with two cushion clamps. One large one around the intake tube, and a small one around the primer line.
Scott Card
CMW E-Lift
07-13-2009, 10:13 AM
Got pics? (extra text)
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
07-13-2009, 11:17 AM
The zip tie
shouldn't chaf the CU tube unless there is movement between the tube and the ziptie..But then again the extra cover is not a bad idea just in case.
Frank
07-13-2009, 01:03 PM
Thanks fella's...I think I'll switch 'em to cushion clamps.
Chad Jensen
07-13-2009, 05:46 PM
Thank you. That is a nice looking engine.
Axel
