Originally Posted by lostpilot28
Well, Vlad makes some good points, but I think the easiest most effective thing to do is to buy tapered pins. Basically they're tapered bolts with the heads cut off (they look like bullets).
When I installed my engine I didn't use them and it was a pain lining up the holes! They were close, but off by maybe a 1/4-inch. Very frustrating. It took several hours to get the engine mounted.
A friend of mine mounted his with the help of an A&P who had the tapered pins...took them all of 1/2-hour to do everything.
Bingo.. I did it solo in 1/2 hour. Made 4 tapered pins and used them to align the motor. Once the pins were in, I snugged the engine up to the mount using a strap, then used the real bolts to push the tapered pins through and out the other side. Getting the engine snugged up tight against the mounts is critical in minimizing the difficulties in aligning all 4 bolts.
If you have a hard time getting the tapered pins in, use phillips screwdrivers that are smaller in diameter than the pins to get your initial alignment.
