Old 07-12-2009, 05:57 AM
ArjanPlomp ArjanPlomp is offline
Lightbulb Retrofit Injection System
Hi all,
With all the LOP discussions and the savings involved, I wonder how much effort it would be to retrofit an injection system. How much work would be involved?
We have an aerosport power O-360 A1A.
Any insight would be appreciated. Saving 1 gln/hr at $4.00 might we worth it.
Arjan Plomp
N83SE, RV8
Old 07-12-2009, 07:08 AM
yakdriver yakdriver is offline
Not a big deal at all. Airflow Performance has a complete bolt on kit with everything you need to convert. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 07-12-2009, 07:22 AM
Walt's Avatar
Walt Walt is offline
It was quite a bit of work and lots of $$ but I justified it when fuel was $4.50 a gal that it would be a 2 year payback. Along with the FI kit you also need both fuel pumps, new fuel/mix cables purge cable (AFP sys), all new fuel lines (not cheap), fuel filter (I rmvd the gascolator and installed an inline flowezy), possibly new fuel pressure gauge/sender, make new brackets for cables etc., anyway you get the idea!
I used a Weldon high pressure pump (which I feel is a better pump than the AFP) and mounted it on the firewall (inside under pass rudder pedals) so I did not have to install the "box" where the AFP fuel pump normally goes.
Would I do it again, yes... but then again I get bored easy and am always looking for something to "improve". LOP operations now are smoother than ever and overall engine runs smoother. I ran a carb for a long time which is a nice simple install and very reliable, I could run LOP with the carb but the rough running would start around peak EGT and often caused me to richen it up just to smooth it out.
Let me know if you have any more questions.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-12-2009, 07:54 AM
Webb's Avatar
Webb Webb is offline
Originally Posted by ArjanPlomp View Post
Hi all,
Arjan Plomp
N83SE, RV8
I'm finding the savings more like 3 gal/hr.
Webb Willmott
Jackson, MS
N32WW
Old 07-12-2009, 07:55 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
If you are looking at going to electronic fuel injection, A company in California just started flight testing two weeks ago of a bolt on system which does complete fuel and ignition. This uses our flight/ Reno race proven electronics first flown in 1994. Kits should be available for both O-320 and O-360 Lycomings.
Dual electric pumps and fuel return lines to the tanks are required.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 07-12-2009, 03:28 PM
frankh's Avatar
frankh frankh is offline
Default Now you've done it
You mentioned dueal electric pumps!..Let the flames begin...
Actually some money can be saved over an AFP conversion..Pumps are available at NAPA for $130 each and all the hoses (and fittings) can be bought (with steel ends) from your local Hydraulics shoppe...be sure to specify the teflon hoses...
Not using a mechanical fuel pump is a given in my very humble opinion which will allow the use of mogas with (almost) zero risk of vapour lock.
Frank
Old 07-13-2009, 07:48 AM
Default Time to do the numbers
Thanks all for your input. I need to do the numbers, financially and work involved. It may be worth, but only if it would allow LOP operations.
Arjan Plomp
Old 07-13-2009, 08:41 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Hello Ross,
Any link to this company in California you mention? Will they be at Osh?
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 07-13-2009, 08:27 PM
AlexPeterson's Avatar
Arjan Plomp
Another thing to consider - LOP is smoother and/or more achievable with EI. When I had the Lasar system, I did a bit of experimenting with LOP using the straight mags of the system vs the EI, something that could only be done with that system (easy to turn off the EI and revert to mags from the cockpit). I concluded then that there was no real advantage to EI when ROP, but a fairly noticeable advantage with EI when LOP.
This said, there is still a big advantage to LOP even with only mags. I just know that the leaner, lower pressure (lower MAP) charge is harder to ignite with aviation spark plugs as compared to a more advanced, auto type spark plug with its larger gap.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 07-14-2009, 06:33 AM
Frank
Frank, what do you use for a check valve, as well as a pressure relief valve to regulate pressure with the NAPA pump?
Alex Peterson
KADC, Wadena, MN
