07-11-2009, 07:16 PM
Empennage Storage ideas
well, we are getting to the end of the tail section and we will try to build the wings in the same small basement shop!!
so, i was looking for some ideas on what others have done for storage of the emp in their 'respectively' small shop!
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
07-11-2009, 07:30 PM
Ceiling
Put them on the ceiling. Works fine.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
07-11-2009, 11:16 PM
I have a similar setup; I drilled from the attic through the ceiling joists for 1/4" threaded rod, then hung padded angle from them. After removing the empennage, I ran some ply between the angles to make a shelf for light items.
EAA Technical Counselor #5357
07-12-2009, 12:44 AM
anywhere you can find room
you can get creative when you are short on space. My wife was pretty understanding and let me hang parts, completed and raw stock, as wall decorations in almost every room of the house for a couple years (I was without a garage for a couple years when building the wings):
07-12-2009, 09:52 AM
Man, you better be carefull hanging such powerful talismans like that in the bedroom.
07-12-2009, 12:31 PM
07-13-2009, 07:16 AM
Here's my solution. A few 2x2's, some old carpet and swaq lamp chains, screwed into the ceiling joists.
Smitty
07-13-2009, 11:08 AM
Originally Posted by DeltaRomeo
Doug, that temp gauge is very disturbing  . I don't know how you handle it. Wow.
Happy Landings!
Kevin "PropellerHead" Schlosser
Tooling Up for an RV-10 build.
Relocating to VA. Planning custom home build around RV workshop with wife's blessing!
My Website: www.propellerhead-online.net
RC Model Club: www.jcsportfliers.org
RC Bowling: www.rcbowling.org
07-13-2009, 11:16 AM
Carry smaller parts upstairs.Put rudder and VS in one closet behind your thousands T-shirts, one aileron in other closet, second one under your bed and HS along the wall. If your shop is really small and you are hanging everything to the ceiling and on shop walls, remember you will bump on them many times when you get bigger parts. I would avoid storage in small shop, you may dent something even if you are super careful.
