Old 07-10-2009, 03:30 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Default Weighing Pro-seal. Which scale
After having built a dozen tanks, Im now building another set and have decided to get more precise than my eye-balls. I have a suspicion that my last set of tanks on my 8 has blisters from possibly not properly weighing/mixing the sealant. Just one possibility of a hundred that has been hashed out in other threads.
So, this time Im gonna weigh it. There are a gazillion kitchen digital scales. I do not know what resolution I need. Is 1gram enough? Seems most go to a gram/.05oz.
A grain of rice weighs ~25mg. Seems I would need resolution to at least that huh?
Also, last time I read a label, it is supposed to be mixed by volume 10:1. Well how is that ever accomplished? Has to be by weight right? How does the 10:1volume translate to weight?
I have 5 tanks to build on this set of wings and Id preferr to get it right this time.
Thanks for your help.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 07-10-2009, 03:34 PM
aturner's Avatar
aturner aturner is offline
I started with a 1g scale and switched to a 0.1g scale. My batches ranged from 5-80 g, and the 1g scale isn't precise enough for the hardener in the smaller batches.
-Andy Turner
RV-10 N784JC
Old 07-10-2009, 03:41 PM
Webb's Avatar
Webb Webb is offline
I used a Salter digital kitchen scale that weighs both grams and ounces. It's flat and works great.
What ever one you buy, put it in a large ziplock bag. When you're done, pull out the nice clean scale and give it to you wife to use in the kitchen.
Webb Willmott
Jackson, MS
N32WW
Old 07-10-2009, 03:58 PM
airguy's Avatar
airguy airguy is offline
I bought a Walmart kitchen digital food scale, measures in grams and ounces. Most of my proseal loads were from 10 to 80 grams. The mix is 10:1 by weight regardless of what measurement you use.
I really enjoyed the "tare" feature, I put a mixing dish on empty, tared it, loaded "about" the right amount of sealant into that dish, noted the weight, tared it again and loaded 1/10 of the original weight of hardener, and mixed away.
Old 07-10-2009, 04:27 PM
Rick6a's Avatar
Rick6a Rick6a is offline
I would not overthink the process. Proseal is relatively forgiving stuff and I doubt improper mixing is the root source of your paint blistering problem. Outdated or worse....improperly stored proseal is a greater threat.
I have only a built a total of 4 leak free RV fuel tanks but in addition to that have repaired a general aviation fuel tank or two and have mixed and applied many hundreds of POUNDS (not ounces) of proseal under the watchful eye of a critical quality control department for extensive use on the taxpayers salt-water combat jets. In the production environment, we mixed proseal and other exotic products using a table top version of the type of scale rigged with sliding weights not unlike the type of scale found in many doctor offices.
For homebuilding purposes, I rely on a good old Royal EX-5 postal scale mixing the proseal 10-1 by WEIGHT as we did on the shop floor...and unless I am missing something, apparently Van's recommends you do the same:
http://www.vansaircraft.com/cgi-bin/...roduct=proseal
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 07-11-2009, 05:50 AM
FredMagare FredMagare is offline
I got mine from here:
http://www.micromark.com/DIGITAL-SCA...CITY,8812.html
Great little scale and fairly inexpensive.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 07-11-2009, 06:03 AM
Kevin Horton's Avatar
I was too cheap to buy a scale. I used some scrap to make a beam scale with one arm 10 times the length of the other one. Gravity hasn't let me down yet.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 07-12-2009, 02:50 AM
npowell npowell is offline
I bought a very inexpensive digital scale at Harbor Freight Tools, and it worked great. I also used it for weighing epoxy resin, superfil and now paint.
N. Powell
RV-9A
In the process of painting
Old 07-12-2009, 09:16 AM
AltonD's Avatar
AltonD AltonD is offline
Originally Posted by Rick6a View Post
That is exactly what I used. Plastic cups, the little ones that sit beside the bathroom sink. I made up about 3 ounces at a shot for one rib at a time.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-26-2009, 03:12 PM
cholladay cholladay is offline
mail scale
