Originally Posted by Andrew Maschmedt
Has anyone machined this boss to accept a fuel pump? So why not get another housing I hear you ask, well parts here in Aus seem to be a bit more expensive than USA and machining, if feasible may be cheaper.
Any advise or alternatives greatly appreciated.
Andrew
I'm not positive that the the -E2D has the boss cast on the inside of the accessory case that holds the pushrod that goes from the eccentric on the magneto idler gear to the fuel pump. If it's there, it may not be drilled since the external fuel pump boss isn't faced off and drilled and tapped. This boss is a hump of about 3/4 in dia. about 3 inches or so long cast into the interior of the accessory case. It holds the pushrod that transfers the action from the eccentric to the arm of the fuel pump.
You may be able to determine if it is there, by removing the left magneto and inspecting the interior of the accessory case with a mirror and flashlight.
If it's there and drilled, then it should be a simple job to face off the external boss then drill and tap for the mechanical fuel pump.
If you have access to an overhaul manual, you can see what I'm talking about and better understand. Hope this makes sense and that anyone with better info will come forward. Mahlon???????????
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
