Old 07-09-2009, 01:50 PM
niblettda niblettda is offline
Default Installing Cherry Max Rivets
This seems like a stupid question, but I've been told there is no such thing.
Do I need a special tool to install Cherry Max rivets, or will a standard pop rivet tool be sufficient?
I've got QB wings and to install the flap gap faring, you need to install cherry max at the wing root. I have the rivets with the kit, I just don't know if there is some special way to install them.
Thanks.
David Niblett
RV-9A QB
http://www.n396dk.org
Old 07-09-2009, 02:04 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Your standard puller will (should) work. I've used mine to set a few CherryMax rivets. Just make sure you keep it aligned straight on, CM rivets are unforgiving in that regard.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 07-09-2009, 02:26 PM
Thanks. That's what I was hoping, since I only have 6 total to install.
David Niblett
RV-9A QB
Old 07-09-2009, 07:16 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Make sure they are CherryMax and not CherryLocs that do need a special nose in the puller to install the locking collars on the rivet stem when set. The newer CherryMax have their own special washers on the stem that set the collar and then fall away. Also make sure that they are the corrrect grip length. To long or too short and they won't lock properly.
Jim Sharkey
Old 07-09-2009, 11:04 PM
C-GRVT C-GRVT is offline
Default EAA "Hints for Homebuilders"
did a "how to" video on installation and removal of CherryMax rivets. Just scroll through the selection
http://www.eaa.org/video/homebuilders.html
Bill Brooks,
Ottawa, Canada
