Old 07-06-2009, 08:18 PM
AX-O's Avatar
AX-O AX-O is offline
Default Question about engine mount bolts
I have a conical 0320 engine (RV-4) and just purchased an engine mount kit with better mount isolator. Seems like the bolts that hold the engine to the engine mount are way too tight. Are those bolts close tolerance bolts or should I run a reamer through the engine mount hole? I don’t want to damage the bolts while installing them. Thanks for any guidance.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 07-19-2009, 02:20 PM
AX-O's Avatar
Vans told me to use a 1/2 inch drill bit or reamer to clean the inside of the holes.
Axel
Old 07-19-2009, 03:17 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Reamer... I had to do the same with mine.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
