EA OIL COOLER II Dimensions needed
Does anyone have a drawing of the EA OIL COOLER II showing hole spacing and flange dimensions? I want to build a angled spacer for mine but hate to pull it off the baffle just to get dimensions. Yes, I should have thought of that when it was off Saturday night!
Thanks.
update - it this is the same as a Stewart Warner 8406R I have found the diagram/drawing.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Reason: update
