Old 07-06-2009, 04:16 AM
AltonD's Avatar
AltonD AltonD is offline
Default Matco nose wheel back-fit kit
New axle for A model nose wheels. Appears to address some concerns.
http://www.matcomfg.com/AXLEASSEMBLY...dv-3657-1.html
I looked, but couldn't find a mention of this in earlier post.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 07-06-2009, 06:35 AM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default It does seem to work well!
Sometime in the last six months Matco's axle was up for discussion on the list. My hangar mate and I purchased the axle and Desser's new two rib tire and did the swap. Does it work better? I don't know but I do like the fact that I can set the bearing load before installing the axle/wheel assembly in the fork.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 07-06-2009, 11:40 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Just finished the axle upgrade on the RV-8A
I just completed the nose gear mod (gear leg, fork, fairing brackets) with all new parts. I went ahead and added the Matco axle based on forum comments. I like the setup much better than the "pucks" ---- still have the RV "wiggle" on the nose gear, so no improvement in that area.
Old 07-06-2009, 12:14 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Here you go----
http://www.vansairforce.com/communit...ad.php?t=38336
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
