Old 07-04-2009, 10:04 AM
Steve A's Avatar
Steve A Steve A is offline
Default K and N Filter Serial Number
I have a IO 360 with the horizontal induction from Van's/Lycoming. The fiberglass induction system had a K and N filter. For some reason, my filter curled up and I am interested in replacing it. Does anyone have the number to the K and N filter? I think I can buy it locally and not have to order it from Van's and wait for it to come in.
Second question: Has anyone else seen this problem. It looks like the filter split down the middle. I had it bracketed in the holder but it apparently bend and the corners peal up letting in unfiltered air.
Thanks.
S S Anderson
RV 7A Flying
Almost out of Phase I
Hot, hot Louisiana
Old 07-05-2009, 03:21 AM
plehrke's Avatar
plehrke plehrke is offline
I have the vertical induction system on the IO-360B (180 HP) and it uses the K&N E-3450. Not sure if the same but you can look it up on the K&N web site if you know the dimensions.
One good thing to do is have a list in the plane (in the POH) of all the consumables so you can easily order replacement parts.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 07-05-2009, 04:31 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Steve A View Post
I have a IO 360 with the horizontal induction from Van's/Lycoming. The fiberglass induction system had a K and N filter....... Does anyone have the number to the K and N filter?
Difficult to say with absolute certainty. The multi-language paperwork included with this K&N air filter supplied by Van's (for use with my horizontally inducted IO-360) seems rather broad and generic in nature. Perhaps the numbers around the bar code can offer some helpful clues.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 07-06-2009, 08:20 AM
Steve A's Avatar
Default Number on Box
I tried to zoom in on the box when I went to Van's web site. My image did not show that clarity and I could not read the number. However I did order a 33-2060 from K and N which from the web site looks like the one I have.
Thanks for the info. I put another hold down aluminum strip on my filter to help hold down the edge and prevent curling. I flew about 1.4 hours this weekend and it seems to be working.
S S Anderson
Lafayette, La.
RV 7A Flying
