Old 07-04-2009, 05:49 AM
dan carley dan carley is offline
Default halo headset
i've been using the halo for a little while now, the hearing part is great but when you talk you really don't get the side tone of your voice. am i doing something wrong or is that the way it is?
thanks
dan carley
rv4
n14ft
Old 07-04-2009, 06:55 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Mine works great. Try turning the side tone level up on your radio. Also make sure the mike is touching your lips and that the flat side is pointed towards you.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 07-04-2009, 07:10 AM
videobobk's Avatar
videobobk videobobk is offline
This is probably a function of the radio (or other equipment) more than the headset. I use the intercom built into my XCOM 760 radio and had to turn the side tone down a bit when I went to the Halo, but realized it had been too loud with my previous headset, also. There should be an adjustment for this in your equipment, or possibly it is muted. If you hear incoming transmissions, you should be able to hear side tone on any headset, IMHO. Check your intercom/radio/audio panel manuals. You might check with other headsets to see if they receive ST. If they do, I don't know what it could be.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 07-04-2009, 07:57 AM
Brantel's Avatar
Brantel Brantel is offline
If you hear regular transmissions, you should hear ST if your radio/intercom is setup correctly.....
After all, there is no separate signal path to the mini speakers inside the headset for the ST vs the regular stuff.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-04-2009, 01:05 PM
Default halo
i found the problem. needed to raise the volume on the headset and lower the intercom. works good
thanks
dan carley
rv4
n14ft
