Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 07-03-2009, 09:09 PM
Phil's Avatar
Phil Phil is offline
Default XM Radar Stops Refreshing - 396
Hi Everyone,
Last weekend I ran into an issue with my 396 where the XM Radar images stopped downloading. They worked fine for most of the flight, but then it stopped all at once... I didn't notice it, until I started to get into some pop-up showers. Then I realized my XM Radar lag time was nearly 60 minutes old.
An inflight reboot fixed the issue.
Today I loaned it out to a friend and he was using it on a trip from Houston to Northern Kansas. The same thing happened to him. The radar images were fine and then they stopped downloading. A reboot fixed the problem.
Has anyone else experienced issues where the XM Radar images stop unannounced?
The XM signal is still great and all of the software/firmware is current.
Phil
Old 07-03-2009, 09:50 PM
petehowell's Avatar
Default Same thing here
Weather seems to come and go as it pleases - I have not had luck with inflight reboots. I plan to have them refresh my subscription tomorrow - but I dont think that will help.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 07-06-2009, 06:26 AM
petehowell's Avatar
Default Happened again
Flew to South Bend and back to retreive Kate yesterday. Both down and back, XM WX worked for a while after takeoff and just when I needed it, it stopped, lost radar and metars, only to have it come back on later in the trip.
Rebooting did not help - XM signal was strong and steady the entire time.
Latest firmware up loaded. Angry call to Garmin in a bit here. Has a refresh solved the problem for anyone? Garmin told me last time it either works or it doesn't. if it is working, a refresh is not needed.
Pete
St. Paul, MN
Old 07-06-2009, 07:33 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Hmmm....just another data point for yesterday - I flew close to 8 hours from SOCAL to Houston, and the XM (on my 696) seemed to behave normally all day. I wonder if this might be a regional data problem?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-06-2009, 08:44 AM
OKAV8r OKAV8r is offline
Default When it quits...
is the "puck" antenna getting hot??
Old 07-06-2009, 08:49 AM
Phil's Avatar
That's a really good question, I can suggest that my puck may have been getting hot. When I've had the issue it has been on hot days.
Is that a known problem, or is that just a suggestion/hypothesis?
Phil
Old 07-06-2009, 09:40 AM
petehowell's Avatar
Lightbulb Idea
Blast tube to the XM puck - I'll tap the baffles tonight!
Pete
St. Paul, MN
Old 07-06-2009, 10:19 AM
mburch's Avatar
mburch mburch is offline
Did you put your XM antenna inside the engine compartment? For what it's worth, that's never been my first choice for a mounting location. The manual says that the max operating temperature for the antenna is 185 F, and also says "Do not store the GXM 30A where exposure to temperature extremes may occur, as permanent damage may result."
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 07-06-2009, 10:30 AM
petehowell's Avatar
Default Sorry Matt
My last post was tounge-in-cheek. Mine is mounted on the glare shield. We were under clouds most of the day - I doubt the puck got anywhere near 185degF.
Maybe I could build a shade tent for it?
Pete
St. Paul, MN
Old 08-01-2009, 11:27 PM
petehowell's Avatar
Angry XMWX MIA again today!
I returned from Colo today and my XM issues continued. I always have WX for the first hour or so and then it stops refreshing. A reboot will sometimes get it back for short while, and finally, even the reboot does not work.
I have solid XM audio lock the whole time. I have latest firmware, and have refreshed via the phone line.
Any thoughts out there? More fun with Garmin on Monday.
Pete
St. Paul, MN
