07-01-2009, 05:27 PM
when fitting the fuel tank fittings??
Am I suppose to use plumbers tape when screwing the "say" flop tube end to the blue fitting? If so, is it regular plumbers tape or special kind?..I am about to safety wire the fitting and wanted to make sure before proceeding..thx all
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
07-01-2009, 05:35 PM
Teflon TAPE should NOT get any where near your airplane. Little pieces can break off and clog up your various filters. Fuel lube (EZ Turn) can be used on most all NPT fuel fittings. However, your flared fittings do not require any lube/sealants at all. Standard practice is to connect them dry. Teflon paste is also commonly used on NPT engine fuel fittings if fuel lube is not used there. Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
07-01-2009, 05:49 PM
yes..thx. How about putting some proseal on the threads, making sure not to get any in the inner flop tube hole.?
Ryan Allen, CFII
E-170/175
07-01-2009, 07:26 PM
Fuel Lube/EZ Turn
Fuel Lube/EZ Turn is all you need. Pro Seal is like sending an 800lb Gorrilla to peel a bannana.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
07-02-2009, 09:42 AM
ok but...I have proseal..I don't have ez lube or the other stuff. The 800# Gorilla still can eat the banana right?
Ryan Allen, CFII
E-170/175
07-02-2009, 09:43 AM
also..how tight are the tank fittings to be...how much torqued..didn't see it listed anywhere?
Ryan Allen, CFII
E-170/175
07-02-2009, 09:57 AM
1. You're going to need it at some point in the build, so why not buy it now? It only costs a few bucks for a tube that will be more than enough for the entire build.
2. What exactly do you think you need the proseal or thread sealant for? The fuel tank fittings are all flared, correct? Flared fittings do not require any sealant or paste at all. They are generally assembled dry.
Regarding the torque--there are torque values in the Standard Aircraft Handbook. Alternatively, Van's also has a pdf on their website that suggests using the "tighten until finger tight and then one or two flats additional with a wrench" method. I'm paraphrasing the latter, so don't quote me, but it is a widely accepted practice that does not require getting a torque wrench on the fitting. Again, I'm pretty sure they have it on their website somewhere. Maybe someone else can provide the link to it. It's been posted here on VAF sometime in the past.
Steve M.
Ellensburg WA
07-02-2009, 10:01 AM
800lb gorrilla
will be needed if you ever have to seperate a fitting put together with Proseal..  ..Either that or a welding torch!
I just used teflon paste..never used fuel lube anywhere on the airplane..works great, just never needed it.
Frank
07-02-2009, 10:48 AM
Vans Torque Specs for Alum Fittings
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
RV 10 - 313RT
Beechrv9a@hotmail.com
07-02-2009, 10:51 AM
Yes...but I am speaking of the L shaped blue fitting that screws into the flop tube...see pic from brad site.
http://www.rv7factory.com/log/060803.html
Ryan Allen, CFII
E-170/175
